BT.com
Wishlist
StarTech.com 2 Port SATA 6 Gbps ExpressCard eSATA Controller Card
Delivery
Standard Due date unavailable
The ECESAT32 2 Port ExpressCard eSATA Controller Card (6 Gbps) offers simple connectivity between a laptop computer with ExpressCard slot and eSATA 3.0 devices - a cost-effective solution for connecting high-speed storage, such as High RPM Hard Drives and Solid State Drives (SSD), which in turn allows for easier data backups and archiving.
With full support for SATA 3.0 hard drives and data transfer speeds of up to 6 Gbps, the ExpressCard adapter features a native PCI Express single chipset that provides enhanced compatibility, reliability and performance for external SATA 600 MB/s storage needs.
The Expresscard is backward compatible with SATA 2.0 devices, providing the versatility to use older storage, and features port multiplier capability with command-based and FIS-based switching for connecting multiple external hard drives to a laptop through a single external SATA connection.
StarTech.com 2 Port SATA 6 Gbps ExpressCard eSATA Controller Card - storage controller - eSATA 6Gb/s - ExpressCard
Storage controller - plug-in module
Bus Type
ExpressCard
eSATA 6Gb/s
Data Transfer Rate
6 GBps
Supported Devices
Hard drive
Channel Qty
2
Max Storage Devices Qty
2
Microsoft Windows XP, Microsoft Windows Server 2003, Microsoft Windows 7, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits)
3.4 cm x 11.2 cm x 2.1 cm
38 g
Host Bus
ExpressCard
Storage Controller
eSATA 6Gb/s
Data Transfer Rate
6 GBps
Supported Devices
Hard drive
Channel Qty
2
2
Marvell 88SE9123
2 x eSATA 6Gb/s - 7 pin external Serial ATA (external)
Compatible Slots
1 x ExpressCard
FCC, RoHS
Limited warranty - lifetime
3.4 cm
11.2 cm
2.1 cm
38 g
Accessories
£10.75
£8.18
£11.06
Scroll to top
