BT.com
Wishlist
StarTech.com 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage
Delivery
Standard Due date unavailable
Add 2 RS-232 serial ports to your PC with this dual voltage universal PCI expansion card. The PCI2S950DV 2 Port Dual Voltage PCI RS232 Serial Adapter Card w/ 16950 UART - lets you add 2 RS-232 serial ports using a PCI expansion slot offering high performance 16950 UART channels/ports for connecting any new or legacy serial peripherals, with data transfer rates of up to 460kbps.
A cost-effective solution for connecting serial modems, POS devices, printers, ISDN terminal adapters and more, the PCI serial card offers dual voltage support, allowing you to use a PCI (5V) or PCI-X (3.3V) slot for installation. The RS232 card also provides broad operating system support, IRQ sharing and a plug and play PCI interface with included standard and low profile slot brackets to guarantee convenient, hassle-free serial device connections on almost any system.
StarTech.com 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI-X
PCI Specification Revision
PCI 2.2
Bus Voltage
Universal (3.3 V & 5.0 V)
Ports
RS-232 x 2
RS-232
Data Transfer Rate
460 Kbps
Microsoft Windows 95, Microsoft Windows 2000, Microsoft Windows 98 Second Edition / Windows ME, Linux Kernel 2.6.11 or later, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
P/N: PEX2PCI4GB, PEX2PCI4
Serial adapter
PCI-X
PCI 2.2
Bus Voltage
Ports
RS-232 x 2
Wired
RS-232
Data Transfer Rate
460 Kbps
2 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI-X
Low-profile bracket, full-height bracket
FCC, RoHS
Software Included
Drivers & Utilities
Limited warranty - lifetime
StarTech.com PCI Express to 4 Slot PCI Expansion System
Accessories
£4.58
£5.13
£4.66
£4.39
£4.22
£4.95
Scroll to top
