BT.com
Wishlist
StarTech.com 2 Port PCI Express SuperSpeed USB 3.0 Card Adapter with UASP Support
Delivery
Standard Due date unavailable
Add 2 USB 3.0 ports to your desktop computer through a PCI Express expansion slot. The PEXUSB3S2 PCI Express USB 3.0 card lets you add two USB 3.0 ports to your PC through a PCI Express slot.
Featuring a native NEC PCI Express host controller chipset, the USB 3.0 standard supports transfer rates of up to 5Gbps, while still providing backward compatibility for older USB 2.0 (480Mbps) and 1.1 (12Mbps) devices.
Enhanced with UASP support (USB Attached SCSI Protocol), this USB 3.0 controller performs up to 70% faster than conventional USB 3.0 when paired with a UASP supported enclosure (Note: UASP requires a compatible operating system). Using a more efficient protocol than the traditional USB BOT (Bulk-Only Transport), UASP technology optimizes transfers by allowing multiple commands to be processed simultaneously, significantly increasing transfer speeds for less wait time on data transfers.
In addition to providing a much faster transfer rate the PEXUSB3S2 USB 3.0 card also supplies 900mA of power per USB port, allowing more and more external devices to operate without the need of an additional power source.
UASP is supported in Windows 8, Server 2012 and Linux kernel 2.6.3 or later. In testing UASP performed with up to a 70% faster read / 40% faster write speed over traditional USB 3.0 at peak performance.
At the same peak in testing, UASP also showed up to an 80% reduction in required processor resources.
Test results were obtained using an Intel Ivy Bridge system, StarTech.com add-on USB 3.0 cards, a UASP-enabled StarTech.com enclosure, and a SATA III solid state drive.
StarTech.com 2 Port PCI Express SuperSpeed USB 3.0 Card Adapter - USB adapter
USB adapter
Plug-in card
Interface (Bus) Type
PCI Express x1
Ports
USB 3.0 x 2
12.1 cm x 7.6 cm x 1.9 cm
60 g
USB, USB 2.0, USB 3.0
Data Transfer Rate
5 Gbps
1 x µPD720200 - NEC
USB 1.1, USB 2.0, USB 3.0
Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
P/N: USB3S2SATA, SAT3510BU3
USB adapter
Plug-in card
PCI Express x1
Ports
USB 3.0 x 2
Wired
Data Transfer Rate
5 Gbps
Processor / Memory
1 x µPD720200 - NEC
2 x USB 3.0 - 9 pin USB Type A
Compatible Slots
1 x PCI Express x1
FCC, RoHS
Software Included
Drivers & Utilities
12.1 cm
7.6 cm
1.9 cm
60 g
Limited warranty - lifetime
50 °C
0 - 80%
StarTech.com 3.5in USB 3.0 SATA External Hard Drive Enclosure w/ Fan, SuperSpeed USB 3.0 SATA Adapter Cable for 2.5in or 3.5in Hard Drives
Accessories
£5.22
£7.41
£9.07
£5.78
£5.82
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Does the job
Reviewed by Don Grunbaum on 15/05/2013
*Just* about fitted in the slot - the heat sink on the graphics controller in the next slot on my PC means that the power socket can't be used. Other than that easily installed on a Windows XP machine.
Scroll to top
