BT.com
Wishlist
StarTech.com 2-port KVM Console Adapter
StarTech.com 2-port KVM Console...
Free delivery
£556.89
Free delivery
Hurry, only 2 left in stock!
£556.89
Add to wishlist
Delivery
Standard 1-3 working days
This 2-port USB crash-cart adapter gives you KVM control of your servers, directly from your laptop. It's a convenient solution for routine diagnostics, maintenance and updates for small-scale server applications, giving you full console access to servers located in small spaces, or congested server racks. It's also perfect for environments where a fixed-installation console server isn't feasible, such as in a server closet or wall-mounted server rack.
The USB crash-cart adapter offers a cost-effective and convenient way to access and control your servers. At a fraction of the cost of a rack-mounted LCD console, installing this easy-to-use adapter means not having to wheel around a conventional server-room crash cart.
Instead of the expense of a dedicated rack console, or hassle of a full-scale crash cart, you can multi-purpose your laptop and save your IT budget by using equipment you already have on hand.
Using the included software, the adapter can do things that regular KVMs can't. The software provides a robust and flexible interface that lets you view your servers on your full laptop screen, without scroll bars, and lets you reduce the viewing window so that you can work on your laptop and servers at the same time to maximize your productivity.
The software also supports file transfers between your laptop and the servers, which is perfect for server software updates and patches. The adapter's software also offers video capture support, so you can record your activity on the servers as video, which you can later use for verification or instructional purposes.
The USB crash cart is easy to install, using the included mounting brackets and 2-in-1 USB and VGA cables. Installing the included software on your laptop is also easy, using the included pre-loaded USB key.
StarTech.com 2-port KVM Console Adapter - Rackmount Crash Cart Adapter - KVM switch - 2 ports
KVM switch - 2 ports - USB
Subtype
KVM
Ports
2 x KVM port(s)
KVM Users Qty
1 local user
AC 120/230 V
244 g
Microsoft Windows Server 2008 R2, Linux 2.6 or later, Microsoft Windows Server 2012, Microsoft Windows Server 2012 R2, Microsoft Windows XP / Vista / 7 / 8 / 8.1 (32/64 bits), Windows 10 (32/64 bits), Apple MacOS X 10.10.x or later
2 years warranty
Bundled Services
2 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
2 x KVM port(s)
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200 @ 60 Hz
Status Indicators
Port status, console, KVM
1 x VGA output - HD-15 , 2 x VGA input - HD-15 , 2 x USB 2.0 - Type B , 4 x USB 2.0 - Type A , 1 x USB 2.0 - Type A - charging port , 1 x console (mini-USB)
External power adapter
AC 120/230 V
2 mounting brackets
2 x VGA / USB cable - 3.05 m , 1 x mini-USB to USB cable
UL, FCC, RoHS
244 g
Scroll to top
