BT.com
Wishlist
StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier
StarTech.com 2 Port High Speed HDMI...
£89.64
3 in stock
£89.64
Add to wishlist
Delivery
Standard 3-5 working days
Split an HDMI audio and video signal to two displays simultaneously.
The ST122HDMI2 2-Port High Speed HDMI Splitter and Signal Amplifier lets you share a single HDMI source signal with audio between two HDMI or DVI (using HDMI to DVI adapter) enabled displays simultaneously.
Supporting True HD 1080p video resolutions, the HDMI splitter acts as a distribution amplifier that enables you to situate your HDMI-capable displays up to 50ft (15m) away from the splitter, and features 3.5mm audio connections, giving you the option of sending your accompanying audio signal through the HDMI cable, or through a separate channel.
The HDMI splitter is easy to install and use with no software or configuration required, for a completely plug-and-play setup that can be used with HDMI output devices such as Blu-ray players or desktop/laptop computers.
StarTech.com 2 Port High Speed HDMI Video Splitter and Signal Amplifier - video/audio splitter - 2 ports
Video/audio splitter - 2 ports
Subtype
HDMI
Ports
2 x HDMI
HDCP compliant
AC 120/230 V
8 cm x 18 cm x 1.9 cm
0.5 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
HDMI
Ports
2 x HDMI
Max Resolution
1080p
HDCP compliant
2 x HDMI output , 1 x HDMI input , 1 x audio input - mini-jack , 2 x audio output - mini-jack
External power adapter
AC 120/230 V
FCC, RoHS
8 cm
18 cm
1.9 cm
0.5 kg
Limited warranty - 3 years
0 - 80%
Accessories
£9.45
£9.12
Scroll to top
