BT.com
Wishlist
StarTech.com 2 Port High Resolution VGA Video Splitter - 350 MHz
StarTech.com 2 Port High Resolution...
£29.96
£29.96
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
This professional grade VGA Video Splitter allows one VGA video source to be displayed on two monitors simultaneously, and features a built-in booster circuit that allows the VGA signal to be extended up to 200 ft.
With support for video bandwidth up to 350MHz, and display resolutions of up to 2048 x 1536 (QXGA), this is the ideal VGA video splitter for presentations, classrooms, tradeshows, or in-store displays where the highest quality video on several monitors is needed.
StarTech.com 2 Port High Resolution VGA Video Splitter - 350 MHz - video splitter - 2 ports
Video splitter - 2 ports
Subtype
VGA
Ports
2 x VGA
AC 230V
22.4 cm x 15.2 cm x 5.2 cm
1.2 kg
2 years warranty
Bundled Services
2 years warranty
P/N: ST121UTPGB
Enclosure Type
Desktop
Subtype
VGA
Ports
2 x VGA
Max Resolution
2048 x 1536 @ 80 Hz
Max Video Bandwidth
350 MHz
Status Indicators
Power, active
2 x VGA - HD-15 , 1 x VGA - HD-15
External power adapter
AC 230V
FCC Part 15
22.4 cm
15.2 cm
5.2 cm
1.2 kg
StarTech.com UTP VGA/Multisync Video Extender Remote and Local Units
Accessories
£15.70
£57.19
£6.90
£11.46
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* Works well but.....
Reviewed by Chris on 17/10/2006
Unit works well but does not include a cable to link from the splitter to the computer.
You will need to have, or order, a male to female 15pSubD (standard VGA monitor cable)
Scroll to top
