BT.com
Wishlist
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio & USB 2.0 Hub
StarTech.com 2 Port DVI VGA Dual...
£160.88
More than 50 in stock
£160.88
Add to wishlist
Delivery
Standard 1-3 working days
Share a keyboard and mouse as well as 1 VGA and 1 DVI displays/monitors between 2 multimedia computers. The SV231DDVDUA 2-port Dual Monitor KVM Switch (DVI+VGA) offers a complete multimedia switching solution, letting users control two Dual Display computers using a single USB mouse and keyboard peripheral set.
With support for high-resolution video interfaces, this dual view KVM switch provides one VGA (analog) and one DVI-I port per computer connection, as well as audio switching capability between connected computers.
Delivering versatility for virtually any application, the DVI/VGA KVM switch features an integrated 2-port USB hub that allows connected USB 2.0 peripherals to be shared between connected computers, eliminating the need to purchase duplicate peripherals.
Suitable for any workspace, the dual monitor KVM switch offers a compact desktop KVM design and features a rugged metal chassis that helps ensure durable performance.
Note: If you're connecting a digital display to the DVI console port, it is recommended you use a DVI-D digital cable. However, if you're connecting an analog display (adapter required), it is recommended you use a DVI-I or a DVI-A cable.
StarTech.com 2 Port DVI VGA Dual Monitor KVM Switch USB with Audio - KVM / audio / USB switch - 2 ports
KVM / audio / USB switch - 2 ports - USB
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2 port USB 2.0 hub, HDCP compliant
16 cm x 10 cm x 5.7 cm
0.75 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1440
2 x VGA - HD-15 , 2 x DVI-I , 2 x keyboard (USB) / mouse (USB) - Type B , 2 x microphone - mini-jack , 2 x speakers - mini-jack , 1 x VGA - HD-15 , 1 x DVI-I , 1 x microphone - mini-jack , 1 x speakers - mini-jack , 2 x keyboard (USB) / mouse (USB) - Type A , 2 x USB 2.0 - Type A
External power adapter
FCC, RoHS
16 cm
10 cm
5.7 cm
0.75 kg
Limited warranty - 3 years
Accessories
StarTech.com 6ft High Speed USB 2.0 Cable
Quicklinx: 2ZWQ | In Stock
£3.87
£5.20
£4.58
£3.87
£14.24
Scroll to top
