BT.com
Wishlist
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub
StarTech.com 2 Port DVI USB KVM...
£129.30
33 in stock
£129.30
Add to wishlist
Delivery
Standard 1-3 working days
Share keyboard, mouse, speakers and a DVI display between two multimedia computers. The SV231DVIUA 2-Port DVI USB KVM Switch lets you control two USB-enabled, DVI-capable computers from a single monitor and peripheral set (keyboard, mouse and speakers), and two additional USB peripherals connected through the built-in USB hub ports.
Featuring convenient hot-key and front panel push-button switching, and high-resolution support (up to 1920x1200), the DVI KVM Switch is perfect for controlling high-performance systems. Ideal for multimedia applications, this KVM switch supports audio and microphone switching either independently, or simultaneously when switching between computers for KVM control.
The DVI USB KVM also features an integrated USB 2.0 hub, which lets you share USB peripherals point as if they were connected directly to the slave computers.
StarTech.com 2 Port DVI USB KVM Switch with Audio and USB 2.0 Hub - KVM / audio / USB switch - 2 ports
KVM / audio / USB switch - 2 ports - USB
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2 port USB 2.0 hub, HDCP compliant
AC 120/230 V
16 cm x 10 cm x 4 cm
1.2 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
1920 x 1200 @ 70 Hz
Status Indicators
Port status
2 x USB 2.0 - Type B , 2 x DVI-I , 2 x audio / headphones - mini-jack , 2 x microphone input - mini-jack , 1 x DVI-I , 2 x USB 2.0 - Type A , 1 x audio / headphones - mini-jack , 1 x microphone input - mini-jack , 2 x keyboard (USB) / mouse (USB) - Type A
External power adapter
AC 120/230 V
FCC, RoHS
16 cm
10 cm
4 cm
1.2 kg
Limited warranty - 3 years
0 - 80%
Min Storage Temperature
-20 °C
Max Storage Temperature
60 °C
Accessories
StarTech.com 6ft High Speed USB 2.0 Cable
Quicklinx: 2ZWQ | In Stock
£3.79
£8.72
£5.20
£4.58
£13.60
Scroll to top
