BT.com
Wishlist
StarTech.com 2 Port Dual DVI USB KVM Switch with Audio & USB 2.0 Hub
StarTech.com 2 Port Dual DVI USB...
£229.63
24 in stock
£229.63
Add to wishlist
Delivery
Standard 1-3 working days
Share a keyboard, mouse and dual DVI displays/monitors between 2 multimedia computers. The SV231DD2DUA 2-port Dual DVI USB KVM Switch allows two PCs, each with dual DVI video outputs, to share two monitors, one microphone and set of speakers, one keyboard and one mouse as well as two other USB peripherals.
An ideal solution for graphic designers, CAD/CAM designers or educational and financial institutions, the dual view KVM Switch allows you to instantly switch back and forth between dual DVI display PCs at the touch of a button, while maintaining professional level video quality on both monitors. The dual DVI switch also features an integrated USB hub port that allows USB 2.0 peripherals such as thumb drives, external hard drives or web cams to be shared between attached systems - eliminating duplicate peripheral costs.
This KVM switch supports DVI-D (digital) signaling only and it is recommended wherever possible to use DVI-D cabling across all PC to KVM and KVM to Console connections to ensure proper function.
StarTech.com 2 Port Dual DVI USB KVM Switch w/ Audio & USB Hub - KVM / audio / USB switch - 2 ports
KVM / audio / USB switch - 2 ports - USB
Subtype
KVM
Ports
2 x KVM / audio / USB
KVM Users Qty
1 local user
Built-in 2 port USB 2.0 hub, HDCP compliant
16.3 cm x 10 cm x 6.6 cm
0.75 kg
3 years warranty
Bundled Services
3 years warranty
Enclosure Type
Desktop
Subtype
KVM
Ports
KVM Local Users Qty
1 local user
Keyboard / Mouse Interface
USB
Max Resolution
2048 x 1536
Status Indicators
Port status
4 x DVI-D , 2 x USB 2.0 - Type B , 4 x audio - mini-jack , 2 x DVI-D , 2 x audio - mini-jack , 4 x USB 2.0 - Type A
External power adapter
FCC, RoHS
16.3 cm
10 cm
6.6 cm
0.75 kg
Limited warranty - 3 years
Accessories
StarTech.com 6ft High Speed USB 2.0 Cable
Quicklinx: 2ZWQ | In Stock
£3.87
£8.20
£13.83
£10.71
£5.20
£4.58
£3.87
Scroll to top
