Click to visit BT.com
BT.com
Wishlist
StarTech.com 2.5in SATA/USB to Dual CF Adpt
Quicklinx: 6BDNWS00
Mfr#: 2CF2SATAR
Standard delivery Delivered within 3-5 working days
This SATA or USB to Dual Compact Flash Solid State Drive adapter features a SATA male power connector and a SATA male data connector, a Mini USB B connector, as well as two Compact Flash ports, allowing you to connect two Compact Flash type media cards to a laptop computer in place of a Serial ATA (SATA) hard drive. The USB 2.0 interface allows it to be connected directly to a Desktop or Notebook PC. The USB connection provides both data and power to the adapter allowing the CF cards to be accessed without requiring any additional adapters or cables. The adapter also features three RAID modes for card configuration; RAID 0 (Stripping), RAID 1(Mirroring), and BIG (Concatenation). A Do-it-yourself SSD solution, the SATA to CF adapter allows Compact Flash, Compact Flash 2, or MicroDrive media to be used on a notebook computer as a bootable hard drive and requires no software or driver installation.
StarTech.com 2.5in SATA or USB to Dual Compact Flash SSD Adapter with RAID - storage controller (RAID) - CompactFlash - SATA 3Gb/s, USB 2.0
Storage controller (RAID)
Bus Type
SATA 3Gb/s, USB 2.0
Compatible Bays
1 2.5"
CompactFlash
Data Transfer Rate
3 GBps
Supported Devices
Disk array (RAID)
RAID Level
RAID 0, RAID 1
Supported Flash Memory
CompactFlash Card type I, CompactFlash Card type II, CompactFlash Card
Microsoft Windows Server 2003, Apple MacOS X 10.4.x, Microsoft Windows Vista / XP, Red Hat Fedora Core 6, Apple MacOS X 10.5.x
6.9 cm x 8.3 cm x 0.9 cm
60 g
1 year warranty
Host Bus
SATA 3Gb/s, USB 2.0
Storage Controller
CompactFlash
Data Transfer Rate
3 GBps
Supported Devices
Disk array (RAID)
RAID Level
RAID 0, RAID 1
2 x CompactFlash
1 storage - Serial ATA-300 - 22 pin Serial ATA , 1 x USB 2.0 - mini-USB Type B
Compatible Bays
1 x internal 2.5"
1 x USB cable - external
FCC, RoHS
Software Included
Drivers & Utilities
1 year warranty
Service & Support Details
Limited warranty - 1 year
6.9 cm
8.3 cm
0.9 cm
60 g
5 °C
50 °C
20 - 80%
