BT.com
Wishlist
StarTech.com 2.5in Encrypted Hard Drive Enclosure - Portable External HDD Enclosure SATA to USB 3.0
Delivery
Standard 3-5 working days
Turn a 2.5" SATA Hard Drive or Solid State Drive into an encrypted external hard drive, with touchpad password security. The S2510BU3PW USB 3.0 HDD Enclosure features Touchpad Encryption, enabling you to turn almost any 2.5-inch SATA hard drive (HDD) or solid state drive (SSD) into an AES-encrypted external hard drive. The enclosure supports large capacity hard drives (tested with up to 1TB), maximizing system storage expansion and backup capabilities.
Using an Advanced Encryption Standard algorithm (256-bit AES), all of the data on hard drives installed within the enclosure is securely protected from unauthorized users. Encryption is performed completely in-hardware and real-time, ensuring maximum performance while eliminating the need for complicated software installation. Access to the encrypted content is allowed through the built-in touchscreen keypad, so any system that supports a USB storage device can be used to access the data.
StarTech.com 2.5in Portable USB 3.0 Encrypted Hard Drive (HDD) Enclosure - storage enclosure - SATA 3Gb/s - USB 3.0
Storage enclosure - external
Bus Type
USB 3.0
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
3 GBps
Supported Devices
Hard drive
Max Storage Devices Qty
1
Product Material
Plastic, steel
Linux, Apple MacOS X, Microsoft Windows Server 2003, Microsoft Windows Server 2008 R2, Microsoft Windows 2000/XP/Vista/7
7.7 cm x 12.3 cm x 0.95 cm
94 g
2 years warranty
2.5"
Host Bus
USB 3.0
Product Material
Plastic, steel
Storage Controller
SATA 3Gb/s
Data Transfer Rate
3 GBps
Supported Devices
Hard drive
1
Fujitsu MB86C311
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - 22 pin Serial ATA
1 x USB 3.0 - 9 pin USB Type A
Carrying case, screwdriver, cleaning cloth
1 x USB cable - external , 1 x USB adapter cable
Tested with up to 1TB 5400 RPM hard drives
FCC, RoHS
Power adapter
7.7 cm
12.3 cm
0.95 cm
94 g
Accessories
£7.71
£7.11
£32.72
Scroll to top
