BT.com
Wishlist
StarTech.com 2.5in Black eSATA USB External Hard Drive Enclosure for SATA HDD
StarTech.com 2.5in Black eSATA USB...
£18.04
£18.04
Add to wishlist
Delivery
Standard Due date unavailable
Turn a 2.5in SATA hard drive into a USB2.0 or eSATA external hard drive. This eSATA/USB External Hard Drive Enclosure transforms virtually any 2.5" SATA (SATA, SATA II, SATA III) hard drive or solid state drive (SSD) into a cost-effective portable storage solution.
Ideal for storing digital multimedia and other demanding applications, the 2.5" SATA hard drive enclosure connects to a host computer using USB 2.0 or eSATA with support for data transfer rates of up to 3Gbps (using eSATA) or 480Mbps (through USB 2.0). Large capacity drives (tested with up to 1TB) can be used to greatly enhance your computer's storage/backup capabilities.
A truly portable solution, the compact hard drive enclosure features lightweight yet durable aluminum construction, as well as a small form factor design that fits perfectly into your pocket or notebook bag when not in use. To eliminate the hassle of having to find a power outlet when you are ready to back up data or load your stored files, the USB/eSATA enclosure offers USB-powered operation, requiring no external power supply.
StarTech.com 2.5in Black eSATA USB External Hard Drive Enclosure for SATA HDD - storage enclosure - SATA 3Gb/s - eSATA 3Gb/s, USB 2.0
Storage enclosure - external
Bus Type
Expansion Bays
1 x internal - 2.5"
Hard Drive Form Factor Compatibility
2.5"
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
Product Material
Aluminium
Power Source
USB bus
Linux, Microsoft Windows 2000, Apple MacOS X 10.4, Microsoft Windows Server 2008 R2, Apple MacOS X 10.6, Apple MacOS X 10.5, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Apple MacOS X 10.7 Lion, Apple OS X 10.8 Mountain Lion, Windows 8 (32/64 bits)
7.2 cm x 13.3 cm x 1.3 cm
90 g
2 years warranty
2.5"
Host Bus
Product Material
Aluminium
Storage Controller
SATA 3Gb/s
Data Transfer Rate
300 MBps
Supported Devices
Hard drive
JMicron JM20316
Bays
1 x internal - 2.5"
1 x SATA 3Gb/s - 7 pin Serial ATA
1 x USB 2.0 - mini-USB Type B , 1 storage - eSATA-300 - 7 pin external Serial ATA
1 x USB cable - external , 1 x eSATA cable - external
Tested with up to 1TB 5400 RPM hard drives
FCC
Power Source
USB bus
Software Included
Drivers & Utilities
7.2 cm
13.3 cm
1.3 cm
90 g
Accessories
£10.80
£8.23
£11.13
£4.28
£5.60
Scroll to top
