BT.com
Wishlist
StarTech.com 1U Vertical Server Rack Cable Management D-Ring Hook - 2.2x5.9in (5.7x15cm)
StarTech.com 1U Vertical Server...
£5.70
10 in stock
£5.70
Add to wishlist
Delivery
Standard 3-5 working days
Add a cable management hook to your server rack or cabinet for strain relief and organization. The CMHOOK1UL Vertical Cable Management D-ring lets you add a 1U metal cable hook to your server rack or cabinet to provide an organized channel for your cables.
Constructed of high-quality steel, the cable D-ring measures 2.2 x 5.9in (5.7 x 15cm) and offers a flexible opening for easy insertion of bundled cables. Providing strain relief for attached cables, multiple cable rings can be attached to your rack where you need them for a versatile cable management solution.
Please see other cable management D-ring products for different size configurations: 1U Cable Management D-ring - 2.2 x 3.9in (5.7 x 10cm) - CMHOOK1U; 1U Cable Management D-ring - 1.8 x 3.9in (4.5 x 10cm) - CMHOOK1UN.
StarTech.com 1U Vertical Rack Cable Management D-Ring - 2.2x5.9in(5.7x15cm) - cable management ring - 1U
Cable management ring
Height (Rack Units)
1U
Product Material
Steel
15.47 cm 5.7 cm
2 years warranty
P/N: 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKHD, RK1219SIDEM, RK1219WALLOH, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK960CP, RKQMCAB12, RKWOODCAB12
Product Material
Steel
Height (Rack Units)
1U
15.47 cm
5.7 cm
RoHS
P/N: 2636CABINET, 2POSTRACK42, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1219SIDEM, RK1219WALLOH, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK619WALLOH, RK812WALLO, RK812WALLOA, RK819SIDEM, RK819WALLOH, RK960CP, RKQMCAB12, RKWOODCAB12
Scroll to top
