BT.com
Wishlist
StarTech.com 1U Low Profile 70mm Socket 775 CPU Cooler Fan with Heatsink & TX3
StarTech.com 1U Low Profile 70mm...
£19.30
£19.30
Add to wishlist
Delivery
Standard Due date unavailable
Keep your socket 775 CPU cool, for optimal system performance; designed for low profile computer cases. This low profile 70mm socket 775 CPU cooler fan is designed specifically for use with processors in rack-mounted and low profile mini systems.
Suitable for Dual Core and high-speed Pentium 4 processors, the low profile socket 775 CPU fan is compatible with Intel socket LGA775 P4 (up to 3.8 GHz) and Dual Core processors and features a dual ball-bearing 70mm fan for exceptional cooling and extended service life.
The CPU fan also features a built-on all-copper base skive fin heatsink and includes the thermal CPU paste that helps the cooling capability of the CPU cooler by thermally bonding the CPU to the heatsink for greater dissipation.
The socket 775 CPU cooler is powered through a simple TX3 connection to the computer power supply.
StarTech.com 1U Low Profile 70mm Socket 775 CPU Cooler Fan w/ Heatsink & TX3 - processor cooler - 1U
Processor cooler
Compatibility
LGA775 Socket
Heatsink Material
Copper
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
4500 rpm
Air Flow
30.8 cfm
Power Connector
3-pin plug
Height (Rack Units)
1U
9.5 cm x 9.5 cm x 2.4 cm
2 years warranty
Processor cooler
Height (Rack Units)
1U
9.5 cm
9.5 cm
2.4 cm
Heatsink & Fan
Compatible With
LGA775 Socket
Processor Compatibility
Pentium 4 - up to 3.8 GHz
Heatsink Material
Copper
Heatsink Dimensions
91 mm x 91 mm x 14 mm
Fan Diameter
70 mm
Fan Height
10 mm
Fan Bearing
Dual ball bearing
Rotation Speed
4500 rpm
Air Flow
30.8 cfm
Power Connector
3-pin plug
UL, RoHS
Sound Emission
39 dBA
StarTech.com 1U Low Profile 70mm Socket 775 CPU Cooler...
£19.30
Save on this ideal PC Build kit!
Save £10.76
£38.47
Scroll to top
