BT.com
Wishlist
StarTech.com 1U Adjustable Mounting Depth Vented Rack Mount Shelf - 175lbs / 80kg
StarTech.com 1U Adjustable Mounting...
£89.37
15 in stock
£89.37
Add to wishlist
Delivery
Standard 3-5 working days
Add a sturdy, adjustable depth shelf into almost any server rack or cabinet. The ADJSHELF Adjustable Mounting Depth Rack Mount Shelf offers a simple way to effectively organize mission critical computer hardware in your server racks and cabinets.
Compatible with all 19in (wide) server racks/cabinets, the fixed rack shelf can be adjusted from 19in to 38in (mount depth) as necessary. A sturdy cold-rolled steel construction provides long term durability and enables a weight capacity of up to 175 lbs (80 kg).
StarTech.com 1U Adjustable Mount Depth Vented Rack Mount Shelf 175lbs/80kg - rack shelf - 1U
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
44.5 cm x 70 cm x 4 cm
4.4 kg
Adjustable depth, vented
1 year warranty
P/N: 4POSTRACK25
Rack shelf
Rack Size
19"
Height (Rack Units)
1U
44.5 cm
70 cm
4 cm
4.4 kg
Weight Limit
79.4 kg
RoHS
1 year warranty
Limited warranty - 1 year
P/N: 2636CABINET, 4POSTRACK12, 4POSTRACK12A, 4POSTRACK12U, 4POSTRACK25, 4POSTRACK25U, 4POSTRACK36, 4POSTRACK42, 4POSTRACKBK, 4POSTRACKHD, 7236CABINET, RK1236BKF, RK2236BKF, RK2536BKF, RK4236BK, RK4242BK, RK960CP, RKQMCAB12, RKWOODCAB12
Scroll to top
