BT.com
Wishlist
StarTech.com 1m USB 2.0 A to Right Angle B Cable - M/M
Clearance
While Stocks Last
Delivery
Standard 3-5 working days
Connect your Mini USB devices, with the cable out of the way. The USBAMB1MD 1m USB to Down Angle Mini USB Cable provides a high quality connection between your Mini USB 2.0 mobile devices (smartphones, GPS, digital cameras, portable hard drives, etc.) and your PC or Mac computer, for everyday tasks such as charging, data synchronization or file transfers.
The down-angled Mini USB connector allows you to access your Mini USB devices, while keeping the cable out of the way, and stress away from the port.
As an alternative, StarTech.com also offers a 1m USB to Up Angle Mini USB Cable (USBAMB1MU), which provides the same convenience as this down-angled cable, but allows you to connect to your Mini USB device from the opposite direction.
StarTech.com 1m Mini USB Cable - A to Down Angle Mini B - USB cable - 1 m
USB cable
Double shielded
90° connector, molded, strain relief
Length
1 m
Connector
4 pin USB Type A - male
Connector (Second End)
Mini-USB Type B - male
USB / USB 2.0
USB cable
Double shielded
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
1 m
Connector
USB / USB 2.0, RoHS
Scroll to top
