BT.com
Wishlist
StarTech.com 1m Black SuperSpeed USB 3.0 Cable - Right Angle A to B - M/M
Select:
Delivery
Standard Due date unavailable
Connect USB 3.0 devices, even in hard to reach areas and tight spaces. The USB3SAB2MRA 2m Black USB 3.0 A to B cable features a right-angled USB ''A'' male connector, enabling you to connect your USB 3.0 Type ''B'' peripherals to your PC, laptop, or server, even in hard to reach areas and tight spaces.
The right-angled USB ''A'' connector positions the cable nearly flush against a wall or other surface, and eliminates the space typically required to accommodate a ''straight'' connection from the cable into the USB port.
Harnessing the full capabilities of the SuperSpeed USB 3.0 standard when used with a USB 3.0 host and device, the 2m cable offers a bandwidth of 5Gbps.
Plus, this right angle USB 3.0 cable also features high quality Shielded Twisted Pair (STP) construction, which helps prevent electro-magnetic interference and ensure reliable data communication.
StarTech.com SuperSpeed USB 3.0 Cable - Right Angle A to B - M/M - USB cable - 2 m
USB cable
Shielded twisted pair (STP)
Molded, right-angled connector
Length
2 m
Connector
9 pin USB Type B - male
Connector (Second End)
9 pin USB Type A - male
USB / USB 2.0 / USB 3.0
USB cable
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
2 m
Connector
USB / USB 2.0 / USB 3.0, RoHS
Scroll to top
