BT.com
Wishlist
StarTech.com 1m 3 ft Black Apple 30-pin Dock Connector to USB Cable with Stepped Connector
Delivery
Standard Due date unavailable
Charge or sync your Apple devices, even when inside a protective case. The USB2ADC1MB 1-meter Apple 30-pin Dock Connector to USB cable for iPhone, iPod and iPad is colored to suit black mobile devices and provides reliable connectivity of your iOS-enabled mobile digital devices to your computer, for syncing and charging.
Plus, this uniquely constructed Dock Connector to USB cable features a stepped Apple Dock Connector, designed by StarTech.com, which unlike a regular connector plugs into your iPhone, iPod or iPad, even when inside a protective case while avoiding the inconvenience of having to constantly remove the cover for every charge/sync.
This durable cable is Apple MFi certified.
If your computer USB port does not deliver sufficient power and you see a "Not Charging" message on your iPad or other Apple device, you can use this 1m 30-pin Dock to USB Cable with the USB 2.0 Fast Charging Adapter (USB2CHADP) in order to fast charge your devices.
StarTech.com 1m Black Apple 30-pin Dock to USB Cable iPhone iPod iPad - charging / data cable - 1 m
Cable
Charging / data cable
American Wire Gauge (AWG)
22/30
Length
1 m
Connector
USB - male
Connector (Second End)
Apple Dock - male
Apple iPad (3rd generation); iPad 1; 2; iPhone 3G, 3GS, 4, 4S; iPod (4G, 5G); iPod classic; iPod mini; iPod nano (1G, 2G, 3G, 4G, 5G, 6G); iPod touch (1G, 2G, 3G, 4G)
Cable Type
22/30
Jacket Material
PVC
Shielding Material
Length
1 m
Plated Connector
Nickel
Connector
4 pin USB Type A - male
Apple Dock connector - male
RoHS
Limited warranty - lifetime
Apple iPad (3rd generation) , Apple iPad 1 , Apple iPad 2 , Apple iPhone 3G, 3GS, 4, 4S , Apple iPod (4G, 5G) , Apple iPod classic , Apple iPod mini , Apple iPod nano (1G, 2G, 3G, 4G, 5G, 6G) , Apple iPod touch (1G, 2G, 3G, 4G)
Scroll to top
