BT.com
Wishlist
StarTech.com 19in Cable Management Panel
StarTech.com 19in Cable Management...
£29.42
10 in stock
£29.42
Add to wishlist
Delivery
Standard 3-5 working days
Organize and manage network, server and KVM cabling in your server rack. The CABLMANAGER2 1U Cable Management Panel mounts to a standard 19" 2 or 4-post rack to help you organize network, server or KVM cabling, using D-Ring hooks.
Constructed of high-quality steel, the cable organizer panel offers 5 removable ABS plastic D-Ring hooks, spaced 4in (105mm) apart for routing cables through your server rack and reducing cable strain. As an added benefit, the hook on either end of the panel can be turned 90° to accommodate horizontal or vertical rack cabling as needed.
Adding a cable manager in between equipment also functions to close off open spaces in the rack, promoting proper airflow.
StarTech.com 1U 19in Metal Rackmount Cable Management Panel - rack cable management kit - 1U - 19"
Rack cable management kit
Height (Rack Units)
1U
1 year warranty
StarTech.com 10U 19in, 12U 19in, 12U 4, 15U 19in, 41U 36in, 4POSTRACKBK
Height (Rack Units)
1U
Rack Size
19"
Limited warranty - 1 year
StarTech.com 10U 19in Wall Mounted Server Rack Cabinet, 12U 19in Hinged Wall Mount Server Rack Cabinet w/ Vented Glass Door, 12U 19in Wall Mounted Server Rack Cabinet, 12U 4 Post Server Equipment Open Frame Rack with Adjustable Posts & Casters, 15U 19in Black Server Rack Cabinet with Fans, 41U 36in Black Server Rack Cabinet, 4POSTRACKBK
Scroll to top
