BT.com
Wishlist
StarTech.com 18in SATA Serial ATA Cable
StarTech.com 18in SATA Serial ATA...
£3.86
£3.86
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered on Thursday
Express Delivery
  • 00 h
  • 00 m
  • 00 s
This high quality SATA cable is designed for connecting SATA drives even in tight spaces. The SATA18 Serial ATA Cable features two 7-pin data receptacles and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 18in SATA Serial ATA Cable - SATA cable - 45.8 cm
SATA cable
Length
45.8 cm
Connectors
1 x 7 pin Serial ATA - female
Connectors (Other Side)
P/N: USB2SATAIDEU, PEXSAT31E1, SATSASBAY425, PEXSAT32, USB2SATAIDGB, BRACKET25SAT, HSB220SAT25B, SAT2510U2S, PEXSATA22I, SATABAY425BK, PEXSATA24E, USB2SATAIDE, PEXSAT2IDE2, SAT2510U2REM, PCISAT2IDE1, PCISATA4R1
Storage Cable Type
SATA cable
Length
45.8 cm
Connectors
StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port eSATA + 4 Port SATA PCI Express x4 SATA Controller Adapter Card, 2 Port SATA 6 Gbps PCI Express SATA Controller Card, 2.5in SATA External Hard Drive Enclosure for 3.5/5.25 Front Drive Bay, 2S1I PCI SATA IDE Combo Controller Adapter Card, 2S2I PCI Express SATA IDE Combo Controller Adapter Card, 4 Drive 2.5in Removable Mobile Rack SAS SATA Backplane, 4 Drive 2.5in Removable SAS SATA Mobile Rack Backplane, 4 Port PCI SATA RAID Controller Adapter Card, Extra 2.5in SATA Hard Drive Enclosure for SAT2510U2REM, USB 2.0 to SATA IDE Adapter
Other bundles
£3.86
Save on Intenso 32GB USB Drive
Save £1.48
£8.36
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
5* It works - that simple
Reviewed by jamesfed on 06/05/2009
Its a simple SATA cable, the joins fit perfectly with my new Blu Ray disk drive and 1TB hard drive and data transfer rate is a fast as specified.
Scroll to top
