Click to visit BT.com
BT.com
Wishlist
StarTech.com 18in Right Angle SATA Cable - F/F
Quicklinx: 5FF8WS00
Mfr#: SATARA18
Length: 45.7cm
Type: Serial
Standard delivery Delivered within 3-5 working days
13 in stock
£3.15
Make a right-angled connection to your SATA drive, for installation in tight spaces. The SATARA18 Right Angle (90-degree) SATA cable (18in) enables you to plug in your SATA hard drive in hard to reach areas or tight spaces, using right-angled SATA connectors to reduce the amount of space required at the connection point and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com 18in Right Angle SATA Cable - F/F - SATA cable - 45.7 cm
SATA cable
Interface Speed
Serial ATA 150/300/600
Cable Features
Right angle connector
Length
45.7 cm
Connectors
1 x 7 pin Serial ATA - receptacle
Connectors (Other Side)
Red
P/N: BRACKET25SAT
Storage Cable Type
SATA cable
Interface Speed
Cable Features
Length
45.7 cm
Red
Colour Category
Red
Connectors
P/N: BRACKET25SAT, PEXESAT322I
StarTech.com 18in Right Angle SATA Cable - F/F Bundle deal on StarTech.com 18in Right Angle SATA Cable - F/F
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£7.24
saving £1.39
Length: 45.7cm
Type: Serial
Price Range Inc VAT: 0 - 50
