Click to visit BT.com
BT.com
Wishlist
StarTech.com 18in Right Angle Latching SATA Serial ATA Cable
Quicklinx: 4LCXWS00
Mfr#: LSATA18RA2
Length: 46cm
Type: ATA
Standard delivery Delivered within 3-5 working days
17 in stock
£4.06
A space-saving, latching right angle SATA hard drive cable, for installations in tight spaces. The LSATA18RA2 Right Angle (90-degree) SATA Cable enables you to plug in your SATA hard drive in hard to reach areas or tight spaces, using right-angled SATA connectors to reduce the amount of space required at the connection point and supports full SATA 3.0 bandwidth of up to 6Gbps when used with SATA 3.0 compliant drives.
The latching connectors lock when connected to a supporting (latchable) SATA port, ensuring a snug, and secured data connection every time to prevent accidental disconnects.
Featuring a low profile, yet durable construction, the flexible design improves airflow and reduces clutter in your computer case, helping to keep the case clean and cool.
StarTech.com Right Angle Latching SATA Serial ATA Cable - SATA cable - 46 cm
SATA cable
Interface Speed
Serial ATA 150/300
Cable Features
Right angle connector, 90 degree connector
Length
46 cm
Connectors
1 x 7 pin Serial ATA - female
Connectors (Other Side)
Red
P/N: PEXSAT31E1, PEXSAT32
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150/300
Cable Features
Length
46 cm
Red
Colour Category
Red
Connectors
StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port SATA 6 Gbps PCI Express SATA Controller Card
StarTech.com 18in Right Angle Latching SATA Serial ATA Cable Bundle deal on StarTech.com 18in Right Angle Latching SATA Serial ATA Cable
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£14.05
saving £4.99
Length: 46cm
Type: ATA
Price Range Inc VAT: 0 - 50
