Click to visit BT.com
BT.com
Wishlist
StarTech.com 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included
Quicklinx: 6PG9WS00
Mfr#: PEX16S952LP
Type: Serial adapter
Compatibility: Unix
Interface: PCI Express
£253.92
The PEX16S952LP PCI Express serial card (16950 UART) lets you turn a low profile PCIe slot into sixteen RS232 (DB9) serial connections. The serial adapter card is based on a native single chip design that allows you to harness the full capability of PCI Express (PCIe), delivering optimum reliability and speed while reducing the load applied to the CPU by as much as 48% over conventional serial cards. This low profile serial card is compatible with a broad range of operating systems, including Windows 2000, XP, 2003, Vista and Windows 7, and features a VHDCI 68 pin connector and serial breakout cable for installation into a single low profile expansion card slot. The card also includes a full-sized bracket, for installation in standard form factor computers.
StarTech.com 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included - serial adapter
Serial adapter
Plug-in card - low profile
Interface (Bus) Type
PCI Express
Ports
RS-232 x 16
6.8 cm x 17.8 cm x 2 cm
1.3 kg
Cabling Type
Serial RS-232
Microsoft Windows 2000, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Windows 8 (32/64 bits)
Serial adapter
PCI Express
Ports
RS-232 x 16
Wired
Cabling Type
Serial RS-232
16 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
FCC, RoHS
Software Included
Drivers & Utilities
6.8 cm
17.8 cm
2 cm
1.3 kg
Service & Support Details
Limited warranty - lifetime
-20 °C
85 °C
5 - 95%
StarTech.com 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included Bundle deal on StarTech.com 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included
Including:
CoolerMaster High Performance Thermal Paste 2g CoolerMaster High Performance Thermal Paste 2g worth £4.83 | in stock
Akasa Cable Tidy Kit Akasa Cable Tidy Kit worth £4.20 | in stock
StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit StarTech.com 7 Piece Precision Screwdriver Computer Tool Kit worth £11.61 | in stock
Best Value Duratool Antistatic Wrist Band Best Value Duratool Antistatic Wrist Band worth £3.60 | while stocks last
C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable C2G 1m 7-pin 180° to 90° 1-Device Serial ATA Cable worth £3.58 | in stock
£273.45
saving £8.26
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £14.98 | while stocks last
£263.91
saving £4.99
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £4.98 | in stock
£258.01
saving £0.88
6PG9 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M In Stock £4.38
6PG9 StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/F In Stock £4.88
6PG9 StarTech.com 10 ft Cross Wired DB9 to DB25 Serial Null Modem Cable - F/M In Stock £4.26
6PG9 StarTech.com 6 ft Straight Through Serial Cable - DB9 F/F In Stock £4.21
6PG9 StarTech.com 6ft Straight Through Serial Cable - DB9 M/F In Stock £4.06
6PG9 StarTech.com DB9 to DB25 Serial Cable Adapter - F/M In Stock £4.89
6PG9 StarTech.com DB9 to DB25 Serial Cable Adapter - F/F In Stock £4.92
Compatibility: Unix
Price Range Inc VAT: 150 - 300
