BT.com
Wishlist
StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F
StarTech.com 16 ft USB 2.0 Active...
£16.42
Hurry, only 1 left in stock!
£16.42
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
Reliably extend the distance of a USB 2.0 device an additional 15ft. This 15ft USB 2.0 Active Extension Cable offers one USB A male connector and one USB A female connector, providing an active, bus-powered extension of a USB 2.0 device connection by up to 15ft (4.5m).
The extension cable (USB Extender) supports high speed USB 2.0 transfer rates of up to 480Mbps.
StarTech.com 16 ft USB 2.0 Active Extension Cable - M/F - USB extension cable - 5 m
USB extension cable
Active cable (signal regeneration)
Length
5 m
Connector
4 pin USB Type A - male
Connector (Second End)
4 pin USB Type A - female
USB / USB 2.0
2 years warranty
P/N: PEXUSB7LP, SAT3520U2RGB, USBPS2PLATE, USB2IR2, ICUSB2321X, UNI3510U2, SAT3520U2R, SAT3510U2, ICUSB1284D25, ICUSB2328, ICUSB2324, SAT3510U2B, 35FCREAD20, ICUSB232PRO, SATCAS35U2GB, ICUSB232C2, 35FCREAD20BK, SATCASE35U2, USB555WG, ICUSB232_2, USBPS2PC, 35FCREAD, 35FCREADBK, FCREADMINI, ICUSB232
USB extension cable
Length
5 m
Connector
USB / USB 2.0, Plug and Play, FCC
2 years warranty
StarTech.com 2 Port USB to RS232 Serial DB9 Adapter Cable, 20-in-1 3.5" Bay Flash Memory Card Reader, 3.5in USB to SATA External Hard Drive Enclosure w/ One Button Backup, 35FCREAD, 35FCREADBK, 4 Port USB to RS-232 Serial DB9 Adapter, 7 Port PCI Express Low Profile High Speed USB 2.0 Adapter Card, 7-in-1 USB 2.0 Multi Media Memory Card Reader, 8 Port USB to RS232 Serial DB9 Adapter Hub, USB to Infrared/IrDA SIR Adapter, USB to PS/2 Keyboard and Mouse Adapter Cable, USB to PS/2 Keyboard and Mouse Converter Adapter, USB Wireless Network Adapter , StarTech.com InfoSafe 3.5" USB 2.0 SATA Hard Drive Enclosure, 3.5" USB 2.0 to IDE/SATA Hard Drive Enclosure, 3.5" USB 2.0 to SATA Drive Enclosure, USB 2.0 Dual 3.5" SATA Drive Enclosure w/RAID
Customer reviews
Write review The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
4* Close to perfect
Reviewed by Anonymous on 14/03/2012
Very good product in that unlike cheaper unbranded ones these can actually be cascaded up to 5 times with no problems. Once you get to 4 or 5 though there is a slight degradation in USB bandwidth, however it's unlikely to impact anyone unless you are running near the limits of USB 2.0. This degradation is a feature of USB technology (according to their tech support), but I'm docking them a point for failing to mention it when they advertise they can be casdaded 5 times.
Scroll to top
