BT.com
Wishlist
StarTech.com 15 ft DisplayPort Cable
Delivery
Standard Due date unavailable
Create high-resolution 4k x 2k connections with HBR2 support between your DisplayPort-equipped devices over longer distances. The DISPLPORT15L DisplayPort 1.2 Cable with latches provides a secure between your DisplayPort-equipped devices and allows for a connection distance of up to 15-feet between your source and display.
The DP cable is capable of providing higher performance than either HDMI or dual link DVI with support for high resolutions of up to 4k x 2k (3840 x 2160) @ 60Hz and a maximum HBR2 bandwidth of 21.6 Gbps. The cable also supports Multi-Stream (MST) for daisy chaining multiple monitors and provides optional audio support.
The DISPLPORT15L long DisplayPort cable ensures that digitally protected content is displayed properly, with both HDCP and DPCP capability.
StarTech.com 15 ft Long DisplayPort 1.2 Cable with Latches - DisplayPort 4k - DisplayPort cable - 4.6 m
DisplayPort cable
Shielded
Latched
Length
4.6 m
Connector
DisplayPort - male
Connector (Second End)
DisplayPort - male
RoHS
P/N: SV231DPUA, VS421DP, SV231DPDDUA, SV431DPUA, SV231DPU
DisplayPort cable
Shielded
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Latched
Length
4.6 m
Connector
20 pin DisplayPort - male
RoHS
StarTech.com 4 Port DisplayPort Video Switch with Audio & IR Remote Control
Scroll to top
