Click to visit BT.com
BT.com
Wishlist
StarTech.com 15 ft Coax High Resolution Monitor VGA Cable - HD15 M/M
Quicklinx: 3ZJZWS00
Mfr#: MXT105MMHQ
This 15 ft Coax VGA Monitor Cable is designed to provide the highest VGA video quality possible. Ideally suited for high resolution VGA applications (1024x768 and above), this high quality coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables and provides superior EMI interference protection by using ferrite cores near the connector ends. This 15ft cable is a reliable solution for any high-res VGA application.
StarTech.com 15 ft Coax High Resolution Monitor VGA Cable - HD15 M/M - VGA cable - 4.6 m
VGA cable
Triple shielded twisted pair coaxial
Cable Features
Nickel plated connectors, ferrite bead
Length
4.6 m
Connectors
1 x 15 pin HD D-Sub (HD-15) - male
Connectors (Other Side)
UL 2919, NEC-CMG
P/N: VGA2TV2WAY2, VS410RVGAA, VS815RVGAGB, VS415RVGAGB, VS415RVGA, ST224MXGB, VID2VGATVGB, VGA2TV2WAYGB, VGA2DVIIGB, VGA2DVII, VGA2TV2WAY, VID2VGATV, ST222MX, DS154
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Cable Features
Length
4.6 m
Colour Category
Connectors
UL 2919, NEC-CMG
StarTech.com 2 Port Matrix High Resolution VGA Video Splitter, 2 Way High Resolution HDTV VGA Video Converter with Scaler, 2 Way VGA HDTV Video Converter with Scaler, 4 Port High Resolution VGA Video Switch with Remote, 4 Port VGA Matrix Video Switch - 250 MHz, 4 Port VGA Video Audio Switch with RS232 control, 8 Port VGA Video Selector Switch, Component / Composite / S-Video to VGA / HDTV Scaler / Converter, Composite and S-Video to VGA Video Converter, VGA to DVI-I Video Converter with Scaler
