BT.com
Wishlist
StarTech.com 15 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable
StarTech.com 15 ft Cat5e Blue...
£4.57
1 in stock
£4.57
Add to wishlist
Delivery
Standard 3-5 working days
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PAT15BL Cat5e Patch Cable (15 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
StarTech.com 15 ft Blue Cat5e / Cat 5 Molded Patch Cable 15ft - patch cable - 4.6 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568B
Wires per Cable
8 wires
Molded
Length
4.6 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: USBVGADOCK2, ECS0016GB, USBVGADOCKGB, ECS0016, USBVGADOCK, PEX100S, MCM110ST, DS5107, PS2UTPEXT, PM1115P, USB6N1DOCKGB, DS8105GB, USB6N1DOCK, BR4100DC, DS16105, DS8105
Network Cable Type
Wiring Scheme
T568B
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
4.6 m
Blue
Connector
RJ-45 - male
RJ-45 - male
StarTech.com 1 Port 10/100 Mbps Parallel Network Print Server, 1 Port PCI Express 10/100 Ethernet Network Interface Adapter Card, 16 Port Enhanced RS232 Serial Console Server, 4-in-1 USB VGA Adapter and Docking Station, 5 Port 10/100 Mbps Desktop Fast Ethernet Switch, 6-in-1 Black USB 2.0 Laptop Docking Station / Port Replicator, DS8105, PS/2 Keyboard and Mouse Extender over Cat 5
Scroll to top
