BT.com
Wishlist
StarTech.com 15 ft 2-in-1 Ultra Thin USB KVM Cable
StarTech.com 15 ft 2-in-1 Ultra...
£16.98
19 in stock
£16.98
Add to wishlist
Delivery
Standard 3-5 working days
The SVECONUS15 15 ft 2-in-1 Ultra Thin USB VGA KVM Cable features an ultra-thin design and is constructed of only high quality materials for durability and long-term reliability. StarTech.com's professional line of 2-in-1 USB KVM switch cables are specifically designed to work with your StarView or Server Remote Control KVM switch, integrating the necessary USB and VGA connections into a single cable - reducing tangles while maintaining excellent performance.
StarTech.com 2-in-1 Ultra Thin USB KVM Cable - video / USB cable - 4.57 m
Video / USB cable
Length
4.57 m
Connectors
15 pin HD D-Sub (HD-15) - male , 4 pin USB Type A - male
Connectors (Second End)
P/N: RKCONS1716GB, SV841HDIEEU, USB-PS2, SV831DUSBU, SV831DUSBAU, SV431DUSBU, SV1631DUSBU, SV565UTPEU, CBCON1716IGB, SV831DUSBA, RACKCONS1716, CABCONS1716I, SV831DUSBGB, SV1631DUSBGB, SV841HDIE, SV1641HDIE, SV841HDIEGB, SV441HDIEGB, SV1641HDIEGB, SV831DUSB, SV1631DUSB, SV565UTPGB, SV565UTP
Video / USB cable
Length
4.57 m
Connectors
PC 99
StarTech.com 16 Port 1U RackMount USB KVM Switch with OSD, 16 Port 1U RackMount USB PS/2 KVM Switch with OSD, 16 Port RackMount USB PS/2 Digital IP KVM Switch, 4 Port Rackmount USB PS/2 Digital IP KVM Switch, 8 Port Rack Mount USB VGA KVM Switch w/ Audio (Audio Cables Included), 8 Port RackMount USB PS/2 Digital IP KVM Switch, 8 Port USB PS/2 KVM Switch Modules for 1UCABCONS/17/19, Enhanced KVM Switch Over IP SV841HDIE, LCD Console w/ 16 Port IP KVM Switch, LCD Console with 16 Port KVM Switch Integrated, SV1641HDI, USB PS2 KVM Console Extender Cat5 Extender , StarTech.com StarView CAB1631HD, SV831HD
Scroll to top
