BT.com
Wishlist
StarTech.com 12U WM Bracket for 12 INCH Equipment
StarTech.com 12U WM Bracket for 12...
£86.40
1 in stock
£86.40
Add to wishlist
Delivery
Standard 3-5 working days
Mount equipment that is up to 12 inches deep, such as patch panels or network switches, to your wall. This wall-mount bracket provides 12U of space for mounting shallow rack-mount equipment that's 12 in. deep or less to the wall, such as patch panels or network switches.
The 12U rack optimizes your working space by efficiently mounting your shallow equipment on your wall instead of taking up desk space or other usable surface areas. It's the perfect solution for your space-limited SoHo (small office, home office) environment or server room because it doesn't take up any floor space.
The wall rack is constructed of solid steel to ensure a sturdy and safe mounting solution for your mission-critical equipment. Also, because the wall-mount rack's mounting holes are positioned 16 in. apart, it exactly matches standard drywall construction framework to ensure simple and secure wall-stud anchoring. The rack also features a rear access panel that can be used to easily run cabling into the rack.
Cage nuts and screws are included with the wall-mount bracket, to save you the hassle of sourcing separate mounting hardware.
If you're looking for a shallow mounting solution with fewer rack units, StarTech.com also offers a 6U wall-mount bracket, and an 8U wall-mount bracket.
StarTech.com Wall-Mount Bracket for Shallow Rack-Mount Equipment - Solid Steel - 12U - wall mount bracket - 12U
Wall mount bracket
Package Content
M6 cage nuts, M5 cage nuts, M5 screws
Height (Rack Units)
12U
Product Material
Steel
52.1 cm x 30.5 cm x 54 cm
56.7 kg
Wall mount bracket
Product Material
Steel
Package Content
Height (Rack Units)
12U
52.1 cm
30.5 cm
54 cm
56.7 kg
Inner Dimensions
45 cm x 52.1 cm
Mounting Kit
Included
Limited warranty - lifetime
Scroll to top
