BT.com
Wishlist
StarTech.com 12U Office Server Cabinet w/ Wood Finish and Casters
StarTech.com 12U Office Server...
£622.04
Hurry, only 1 left in stock!
£622.04
Add to wishlist
Delivery
Standard 1-3 working days
Store IT equipment discreetly in the office, with a stylish wood-finished server cabinet. The RKWOODCAB12 12U Office Server Cabinet lets you store your server, network or AV equipment discreetly in the office, with a stylish wood finish.
Designed to blend in with your office or boardroom furniture, this 12U server cabinet features wood laminate exterior panels with a shaded glass front window that keeps your equipment visible for monitoring, as well as front and rear key-locks to prevent unauthorized access. To help keep your valuable equipment running cooler, we've included a ventilation panel to maximize airflow. The cabinet also features durable casters, so that positioning your server equipment as needed isn't a hassle.
The 4-post enclosed rack supports a weight capacity of up to 300lbs (136kg) and offers rails with adjustable mounting depth from 16.7in (423mm) to 20.6in (523mm) to accommodate various sizes of equipment. Making it easy to route your cables where you need them, the 12U cabinet offers cable grommets on the rear and top panels, and a cable entry panel at the base.
StarTech.com 12U Office Server Cabinet w/ Wood Finish and Casters - rack - 12U
Rack
Wood
Height (Rack Units)
12U
56 cm x 66 cm x 66.4 cm
Key lock, casters
2 years warranty
Rack
Height (Rack Units)
12U
56 cm
66 cm
66.4 cm
Wood
Weight Limit
136.1 kg
Mounting Kit
Included
Key lock, casters
RoHS
Scroll to top
