BT.com
Wishlist
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack w/ Casters / Levelers & Cable Hooks
StarTech.com 12U Adjustable Depth...
£186.94
Hurry, only 2 left in stock!
£186.94
Add to wishlist
Delivery
Standard 1-3 working days
Store your servers, network and telecommunications equipment in an adjustable 12U open-frame rack. The 4POSTRACK12U 12U Server Rack lets you store your servers, network and telecommunications equipment in a sturdy, adjustable depth open-frame rack.
Designed with ease of use in mind, this 12U rack offers easy-to-read markings for both rack units (U) and depth, with a wide range of mounting depth adjustments (22 - 40in) that make it easy to adapt the rack to fit your equipment.
This durable 4-post rack supports a static loading capacity of up to 1200lbs (544kg), and offers compliance with several industry rack standards (EIA/ECA-310, IEC 60297, DIN 41494) for a universal design that's compatible with most rack equipment.
For a complete server storage solution that saves you time and hassle, the rack includes optional accessories such as casters, leveling feet and cable management hooks. The base is also pre-drilled for securely fastening the rack to the floor if needed, providing you with additional stability to better suit your server environment.
StarTech.com 12U Adjustable Depth Open Frame 4 Post Server Rack - relay rack - 12U
Relay rack
Package Content
Phillips screwdriver, 16 x M6 nut, 16 x M6 screw, 2 base brackets, 2 top brackets, 48 x M8 bolts, 8 x corner sections, 48 x M8 washers, M8 (13mm) wrench, 4 x casters, 4 x levelling feet, 16 x M6 flange nuts, M6 (10mm) wrench, 4 x centre sections, 2 x right vertical rails, 2 x left vertical rails, 4 x grounding wires, 16 x M6 flat washers, 24 x M6 cage nuts, 24 x PVC cup washers, 24 x M6 Philips head screws, 4 x cable management hooks, 4 x hook mounting screws
Height (Rack Units)
12U
Product Material
Steel
60 cm x 66.18 cm x 63.75 cm
17 kg
Adjustable depth, flat pack, 4 post rack mountable, 4 post
2 years warranty
Relay rack
Product Material
Steel
Package Content
Height (Rack Units)
12U
60 cm
66.18 cm
63.75 cm
17 kg
Inner Dimensions
46.5 cm x 55.9 cm x 53.8 cm
Weight Limit
544.3 kg
Mounting Kit
Included
EIA-310-E, RoHS, DIN 41494, IEC 60297-3-100, ECA-310-E
2 years warranty
Limited warranty - 2 years , Technical support - lifetime
Scroll to top
