BT.com
Wishlist
StarTech.com 12U 19in Wall Mount Side Mount Open Frame Rack Cabinet
StarTech.com 12U 19in Wall Mount...
£219.68
£219.68
Add to wishlist
Delivery
Standard Due date unavailable
Wall Mount your Server or Networking Equipment Sideways, for Easy Access. The RK1219SIDEM Wall Mount/Side Mount Deep Open Frame Rack/Cabinet (12U, 19in Wide) lets you mount your servers, A/V or network equipment facing perpendicular to the wall for easy access to mounted devices and equipment. The cabinet/rack features open access to both the front and back of your devices, making it easy to adjust cabling, view LEDs and access configuration buttons as needed; plus, the nature of the sidemount configuration allows for deeper mounting depths than typical wallmount racks. This TAA compliant product adheres to the requirements of the US Federal Trade Agreements Act (TAA), allowing government GSA Schedule purchases.
Constructed of high-quality SPCC cold-rolled steel, for strength and durability, the open frame equipment rack allows for maximum airflow while still supporting a maximum weight capacity of 159 kg (350 lbs). The wall mount rack also ships complete with all of the M5 screws and cage nuts required to mount your equipment, saving the expense of purchasing them separately.
StarTech.com 12U 19in Wall Mount Side Mount Open Frame Rack Cabinet - mount cabinet - 12U
Mount cabinet
Placing / Mounting
Wall mountable
Rack Size
19"
Height (Rack Units)
12U
Product Material
Steel
53.7 cm x 55.8 cm x 65.5 cm
21.8 kg
Mount cabinet
Placing / Mounting
Wall mountable
Product Material
Steel
Rack Size
19"
Height (Rack Units)
12U
53.7 cm
55.8 cm
65.5 cm
21.8 kg
EIA-310-D, RoHS
Limited warranty - lifetime
Scroll to top
