BT.com
Wishlist
StarTech.com 12in Micro SATA Extension Cable
Delivery
Standard Due date unavailable
This 12in micro SATA extension cable features one male and one female micro SATA connector, allowing you to extend a micro SATA device connection by up to 1ft. A cost-effective solution, the extension cable not only simplifies drive installation by overcoming typical connection limitations, but also reduces the risk of damage to the drive or motherboard micro SATA connectors that could result from straining or "stretching" the cable to make the necessary data connection. The micro SATA extension cable is constructed of high quality materials to ensure a permanent solution.
StarTech.com SATA extension cable - 30.5 cm
Length
30.5 cm
Connector
16 pin Micro Serial ATA - male
Connector (Second End)
16 pin Micro Serial ATA - female
Storage Cable Type
Length
30.5 cm
Connector
RoHS
Scroll to top
