Click to visit BT.com
BT.com
Wishlist
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter
5.0*
Quicklinx: 4KX6WS00
Mfr#: PYO2LP4SATA
Length: 0.15m
Type: ATA
Standard delivery Delivered within 3-5 working days
More than 50 in stock
£3.91
This 12in LP4 to SATA Power Y Cable Adapter features two Serial ATA power (female) connectors and one LP4 male connection - a reliable solution that lets you power two SATA drives using a single LP4 connection to the computer power supply. This durable LP4/SATA Y cable adapter is 1ft in length, giving you enough cable slack to position drives as needed within the computer case while saving the cost and hassle of upgrading a power supply for compatibility with Serial ATA drives.
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter - power adapter
Power adapter
Connectors
1 x 4 PIN internal power - male
Connectors (Other Side)
2 x 15 pin Serial ATA power - female
P/N: ATXPOW330HS, ATXPOWER300B, ATXPOW400DF, ATXPOW350PRO, ATXPOW350DF, ATXPOW250PRO, ATXPOW300PRO, ATXPOWER250, ATXPOWER300
Power adapter
Connectors
P/N: ATXPOW250PRO, ATXPOW300PRO, ATXPOW330HS, ATXPOW350DF, ATXPOW350PRO, ATXPOW400DF, ATXPOWER250, ATXPOWER300, ATXPOWER300B, S25SLOTR
StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter Bundle deal on StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£13.90
Customer reviews
Write a review for the StarTech.com 12in LP4 to 2x SATA Power Y Cable Adapter here!
Does exactly what it's meant to...
Reviewed by Gary. Review Posted 13/01/2009
What more can I say?
Length of cabling is good if there is a chance of a bit of a stretch to fit to drive...
  • Overall 5*
  • Ease of use 5*
  • Value for money 5*
Does It's Job
Reviewed by Anonymous Review Posted 04/11/2009
Does it's job! no more, no less!
  • Overall 5*
  • Ease of use 5*
The opinions expressed in this reviews section are those of our customers and not of BT Shop. Nothing contained herein amends BT Shop’s terms and conditions.
Length: 0.15m
Type: ATA
Price Range Inc VAT: 0 - 50
