Click to visit BT.com
BT.com
Wishlist
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable
Quicklinx: 6PFHWS00
Mfr#: LSATA12RA1
Length: 30cm
Type: SATA
Express delivery Delivered on Tuesday
Hurry, only 3 left in stock!
£3.92
This 12in right-angled latching SATA cable features a (straight) female Serial ATA connector as well as a right-angled (female) SATA connector, providing a simple connection to a Serial ATA drive even if space near the drive's SATA port is limited. The cable offers latching connectors, which ensure secure connections for SATA hard drives and motherboards that support this feature. Once the right-angled SATA connector has been inserted into the drive's SATA data port, the shaft of the cable is seated flush with the rear panel of the drive, eliminating the clutter of excess cable at the connection point - an ideal solution for small or micro form factor computer cases. The right angled SATA cable features a thin, narrow construction that helps to improve airflow within the computer case; the cable features a rugged, yet flexible design that makes it easy to make the SATA connection as needed.
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable - SATA cable - 30 cm
SATA cable
Interface Speed
Serial ATA 150/300
Cable Features
Right angle connector, latched
Length
30 cm
Connectors
1 x 7 pin Serial ATA - female
Connectors (Other Side)
Red
P/N: PEXSAT31E1, PEXSAT32
Storage Cable Type
SATA cable
Interface Speed
Serial ATA 150/300
Cable Features
Length
30 cm
Red
Colour Category
Red
Connectors
StarTech.com 1x eSATA + 1x SATA 6Gbps PCI Express SATA Controller Card, 2 Port SATA 6 Gbps PCI Express SATA Controller Card
StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable Bundle deal on StarTech.com 12in Latching SATA to Right Angle SATA Serial ATA Cable
Including:
Corsair Flash Voyager Slider - 32GB - USB 3.0 Corsair Flash Voyager Slider - 32GB - USB 3.0 worth £9.88 | in stock
£13.91
Length: 30cm
Type: SATA
Price Range Inc VAT: 0 - 50
