BT.com
Wishlist
StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable
StarTech.com 12in Fan Adapter - TX3...
£3.31
12 in stock
£3.31
Add to wishlist
Delivery
Standard 3-5 working days
The StarTech.com 6" 3-pin to Large Internal Power CPU Fan Adapter Cable allows a fan with a TX3 motherboard connector to draw power from a standard LP4 power supply connector.
StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable - power splitter - 15.2 cm
Power splitter
Length
15.2 cm
Connectors
4 PIN internal power - male
Connectors (Second End)
4 PIN internal power - female , 3 PIN internal power - male
P/N: ATX2POWER430, ATX2POWER530, FAN7X10TX3, FANP1003LD, FAN370PRO, FANDURONTB, FANP2SECC, FANBOX2
Power splitter
Length
15.2 cm
Connectors
StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan
Scroll to top
