Click to visit BT.com
BT.com
Wishlist
StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable
Quicklinx: 3ZM1WS00
Mfr#: CPUFANADAPT
Type: Power
Standard delivery Delivered within 3-5 working days
More than 50 in stock
£3.22
The StarTech.com 6" 3-pin to Large Internal Power CPU Fan Adapter Cable allows a fan with a TX3 motherboard connector to draw power from a standard LP4 power supply connector.
StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable - power splitter - 15.2 cm
Power splitter
Length
15.2 cm
Connectors
1 x 4 PIN internal power - male
Connectors (Other Side)
1 x 4 PIN internal power - female , 1 x 3 PIN internal power - male
P/N: ATX2POWER430, ATX2POWER530, FAN7X10TX3, FANP1003LD, FAN370PRO, FANDURONTB, FANP2SECC, FANBOX2
Power splitter
Length
15.2 cm
Connectors
StarTech.com 430 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, 530 Watt ATX12V 2.3 80 Plus Computer Power Supply Active PFC, Replacement 70mm TX3 Dual Ball Bearing CPU Cooler Fan
StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable Bundle deal on StarTech.com 12in Fan Adapter - TX3 to 2x LP4 Power Y Splitter Cable
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£7.31
saving £1.39
Type: Power
Price Range Inc VAT: 0 - 50
