BT.com
Wishlist
StarTech.com 100 ft Coax High Resolution VGA Monitor Extension Cable - HD15 M/F
StarTech.com 100 ft Coax High...
£57.19
3 in stock
£57.19
Add to wishlist
Delivery
Standard 3-5 working days
This 100ft High Resolution VGA Extension Cable is designed to provide the highest video quality possible through VGA.
Ideally suited for high resolution VGA applications, this high quality male to female coaxial VGA extension cable helps to eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com Coax High Resolution VGA Monitor Extension Cable - VGA extension cable - 30.4 m
VGA extension cable
Coaxial
Molded
Length
30.4 m
Connector
HD-15 - male
Connector (Second End)
HD-15 - female
P/N: ST128UTPEAGB, ST122VGAU, ST128WGB, ST124WGB, ST122WGB, ST128UTPEA, ST128W, ST124W, ST122W, ST128UTPE, ST124UTPE, ST224MXGB, ST122PROAGB, ST124PROGB, ST122PROGB, ST128GB, ST222MX, ST122PROA, ST1216PRO, ST128PRO, ST122PRO, ST124PRO, ST128
VGA extension cable
Coaxial
Plated Connector
Nickel
Molded
Length
30.4 m
Connector
15 pin HD D-Sub (HD-15) - female
Startech Converge A/V 4 Port VGA Video Splitter - Wall Mountable, 8 Port VGA Video Splitter - Wall Mountable , StarTech.com 16 Port High Resolution VGA Video Splitter - 400 MHz, 2 Port High Resolution VGA Video Splitter with Audio - 400 MHz, 2 Port Matrix High Resolution VGA Video Splitter, 2 Port VGA Auto Switch, 2 Port Wall Mount VGA Video Splitter, 4 Port High Resolution VGA Video Splitter - 350 MHz, 4 Port VGA Matrix Video Switch - 250 MHz, 4 Port VGA Video Extender over Cat 5 (UTPE Series), 8 Port VGA and Audio over Cat 5 Video Extender, 8 Port VGA Video Extender over Cat 5 (UTPE Series) , StarTech.com VideoView 8 Port VGA Video Splitter, Pro 2 Port High Resolution 350 MHz Video Splitter, Pro 8 Port High Resolution 300 MHz Video Splitter
Scroll to top
