BT.com
Wishlist
StarTech.com 100 ft Cat5e Blue Molded RJ45 UTP Cat 5e Patch Cable
StarTech.com 100 ft Cat5e Blue...
£26.24
4 in stock
£26.24
Add to wishlist
Delivery
Standard 3-5 working days
Make Fast Ethernet network connections using this high quality Cat5e Cable, with Power-over-Ethernet capability. The M45PATCH100B Cat5e Patch Cable (100 ft) meets or exceeds all Cat 5e specifications to ensure reliable Ethernet network connections, and features a durable blue PVC jacket that enables you to color code your network cable runs as needed. To ensure long-lasting performance, this high quality Cat5e patch cable features molded PVC strain relief that prevents the RJ45 connector termination points from bending at sharp angles - reducing the risk of cable damage, which could decrease network performance. Constructed of only top quality materials, this Cat5e Patch Cord delivers reliable performance.
StarTech.com 100 ft Blue Cat5e / Cat 5 Molded Patch Cable 100ft - patch cable - 30.4 m - blue
Patch cable - CAT 5e
Unshielded twisted pair (UTP)
Wiring Scheme
T568A
Wires per Cable
8 wires
Molded
Length
30.4 m
Connector
RJ-45 - male
Connector (Second End)
RJ-45 - male
Blue
P/N: ST121UTPDVEU, ST124UTPEAGB, ST128UTPEAGB, STUTPEALRGB, ST121UTP23GB, ST121UTPDVGB, ST128UTPEA, ST121HDMIT, STUTPEALR, ST124UTPEA, ST121UTPDVI, NETRS2321E, DS5107, CPNTUTPEXTA, ST121UT232GB, ST121UTP232, PS2UTPEXT, SVIDUTPEXTA, SVIDUTPEXT, CPNTUTPEXT, COMPUTPEXTA, STUTPRXL, ST128UTPE, ST124UTPE
Network Cable Type
Wiring Scheme
T568A
American Wire Gauge (AWG)
24
Wires per Cable
8 wires
Pairs per Cable
4 pairs
Molded
Length
30.4 m
Blue
Connector
RJ-45 - male
RJ-45 - male
UL
StarTech.com 1 Port 10/100 Mbps Parallel Network Print Server, 1 Port Cat5 USB Extender, 1 Port RS-232/422/485 Serial over IP Ethernet Device Server, 4 Port VGA Video Extender over Cat 5 (UTPE Series), 5 Port 10/100 Mbps Desktop Fast Ethernet Switch, 8 Port VGA and Audio over Cat 5 Video Extender, 8 Port VGA Video Extender over Cat 5 (UTPE Series), Component Video Extender over Cat 5, Composite Video Extender over Cat 5 with Audio, Converge A/V Component Video (YPbPr) Cat5 Extender Transmitter and Receiver, DS8105, DVI Video Extender over Cat5, HDMI Video Extender over Cat 5, PS/2 Keyboard and Mouse Extender over Cat 5, RS-232 Serial Ethernet IP Adapter (Device Server, Console Server), Serial DB9 RS232 Extender over Cat 5 - Up to 3300 ft (1000 meters), S-Video Extender over Cat 5, S-Video Video Extender over Cat 5 with Audio, VGA Video Extender over Cat 5 Remote Receiver with Audio, VGA Video Extender over Cat 5 with RS232 , StarTech.com Converge A/V 4 Port VGA and Audio over Cat 5 Video Extender , StarTech.com USBthere 4 Port 100m USB Extender
Scroll to top
