Click to visit BT.com
BT.com
Wishlist
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M
Quicklinx: 3ZMKWS00
Mfr#: SCNM9FM
Length: 3m
Type: Serial
Stock Status: Clearance
Express delivery Delivered on Wednesday
15 left in stock
£4.38
This 10 ft Cross Wired Serial/Null Modem Cable features one DB9 female and one DB9 male connector, allowing you to connect a serial printer to a 9 pin serial port, or transfer files from PC to PC via serial connection. This serial/null modem cable is designed to provide a reliable, long-lasting connection.
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M - null modem cable - 3 m
Null modem cable
Length
3 m
Connectors
1 x 9 pin D-Sub (DB-9) - male
Connectors (Other Side)
1 x 9 pin D-Sub (DB-9) - female
StarTech.com 1, 16, 2, 2 Serial/1, 2S1P, 4, 8, PCI1S650DV, PCI2S650DV, PCI4S650DV, RS-232
Null modem cable
Length
3 m
Connectors
StarTech.com 1 Port CardBus PCMCIA Parallel Laptop Adapter Card, 1 Port ExpressCard RS232 Serial Adapter Card with 16950 UART, 1 Port ISA RS232 Serial Adapter Card with 16550 UART, 1 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 1 port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 1 Port PCI Dual Voltage Parallel Adapter Card, 1 Port PCI Low Profile RS232 Serial Adapter Card with 16550 UART, 1 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 1 Port PCI RS232 Serial Adapter Card with 16550 UART, 1 Port RS-232/422/485 Serial over IP Ethernet Device Server, 16 Port Enhanced RS232 Serial Console Server, 16 Port Low Profile RS232 PCI Express Serial Card - Cable Included, 2 Port ExpressCard Serial Adapter Card, 2 Port ISA RS232 Serial Adapter Card with 16550 UART, 2 Port Low Profile Native RS232 PCI Express Serial Card with 16550 UART, 2 Port Low Profile PCI RS-422/485 Card, 2 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI Express RS232 Serial Adapter Card with 16550 UART, 2 Port PCI RS232 Serial Adapter Card w/ 16950 UART - Dual Voltage, 2 Port PCI RS232 Serial Adapter Card with 16550 UART, 2 Port PCI RS422 RS485 DB9 Serial Adapter Card, 2 Port PCI RS422/485 Serial Adapter Card With DB9, 2 Port RS232/422/485 PCI Serial Adapter Card w/ ESD Protection, 2 Port USB to RS232 Serial DB9 Adapter Cable, 2S1P PCI Serial Parallel Combo Card with 16550 UART, 4 Port ExpressCard 16C950 Serial Card, 4 Port Low Profile Native RS232 PCI Express Serial Card with 16950 UART, 4 Port PCI Express RS232 Serial Adapter Card with 16950 UART, 4 Port PCI Express Serial Card, 4 Port PCI RS232 Serial Adapter Card, 4 port PCI RS232 Serial Adapter Card with 16550 UART, 8 Port Low Profile RS232 PCI Serial Card with 16950 UART, 8 Port PCI Express Low Profile Serial Adapter Card, 8 Port USB to RS232 Serial DB9 Adapter Hub
StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M Bundle deal on StarTech.com 10 ft DB9 RS232 Serial Null Modem Cable F/M
Including:
Intenso 32GB Rainbow Transparent USB Flash Drive Intenso 32GB Rainbow Transparent USB Flash Drive worth £5.48 | in stock
£8.47
saving £1.39
Length: 3m
Type: Serial
Price Range Inc VAT: 0 - 50
