BT.com
Wishlist
StarTech.com 10 ft Coax High Resolution VGA Monitor Cable HD15 M/M
Delivery
Standard Due date unavailable
This 10ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 10 ft Coax High Resolution VGA Monitor Cable HD15 M/M - VGA cable - 3 m
VGA cable
Triple shielded twisted pair coaxial
Molded, ferrite bead
Length
3 m
Connector
HD-15 - male
Connector (Second End)
HD-15 - male
P/N: RKCONS2001GB, ST122LEU, RACKCONV1901, RACKCONS2001, USB2VGADVI, SV431DDVDUA, SV231DDVDUA, VS410RVGAA, SV431DDUSB, SV231DDUSB, ST122LE, AGPVID5500A, ST128LGB, ST124LGB, ST122LGB, VGAHD2HDMIGB, ST128L, ST124L, ST122L, VGAHD2HDMI, DVI2VGA, ST222MX
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Plated Connector
Nickel
Length
3 m
Connector
StarTech.com 2 Port Matrix High Resolution VGA Video Splitter, 2 Port VGA Video Splitter - 250 MHz, 4 Port VGA Video Audio Switch with RS232 control, 4 Port VGA Video Splitter - 250 MHz, High Res RackMount LCD Console for 19" Rack, USB VGA and DVI Dual Port External Video Adapter, VGA to HDMI Video Converter with Audio , StarTech.com StarView DVI/VGA USB KVM Switch with Audio , StarTech.com VGA Video Splitter / Distribution Amplifier 8 Port - 250 MHz
Scroll to top
