Click to visit BT.com
BT.com
Wishlist
StarTech.com 10 ft Coax High Resolution VGA Monitor Cable HD15 M/M
Quicklinx: 6PF2WS00
Mfr#: MXT101MMHQ10
This 10ft High Resolution VGA Monitor Cable is designed to provide the highest video quality possible through VGA. Ideally suited for high resolution VGA applications, this high quality male to male coaxial VGA cable eliminates picture "ghosting" and fuzzy images inherent to non-coaxial cables, and provides superior EMI interference protection by using ferrite cores near the connector ends.
StarTech.com 10 ft Coax High Resolution VGA Monitor Cable HD15 M/M - VGA cable - 3 m
VGA cable
Triple shielded twisted pair coaxial
Cable Features
Moulded , nickel plated connectors, ferrite bead
Length
3 m
Connectors
1 x 15 pin HD D-Sub (HD-15) - male
Connectors (Other Side)
P/N: RKCONS2001GB, ST122LEU, RACKCONV1901, RACKCONS2001, USB2VGADVI, SV431DDVDUA, SV231DDVDUA, VS410RVGAA, SV431DDUSB, SV231DDUSB, ST122LE, AGPVID5500A, ST128LGB, ST124LGB, ST122LGB, VGAHD2HDMIGB, ST128L, ST124L, ST122L, VGAHD2HDMI, DVI2VGA, ST222MX
VGA cable
Shielding Material
American Wire Gauge (AWG)
28
Cable Features
Length
3 m
Colour Category
Connectors
StarTech.com 2 Port Matrix High Resolution VGA Video Splitter, 2 Port VGA Video Splitter - 250 MHz, 4 Port VGA Video Audio Switch with RS232 control, 4 Port VGA Video Splitter - 250 MHz, High Res RackMount LCD Console for 19" Rack, USB VGA and DVI Dual Port External Video Adapter, VGA to HDMI Video Converter with Audio , StarTech.com StarView DVI/VGA USB KVM Switch with Audio , StarTech.com VGA Video Splitter / Distribution Amplifier 8 Port - 250 MHz
