BT.com
Wishlist
StarTech.com 1 Port USB Wireless N Network Print Server with 10/100 Mbps Ethernet Port 802.11 b/g/n
StarTech.com 1 Port USB Wireless N...
£56.32
£56.32
Add to wishlist
Delivery
Standard 1-3 working days
Express Delivered tomorrow
Express Delivery
  • 00 h
  • 00 m
  • 00 s
The PM1115UWGB Wireless-N Print Server lets you share a standard USB printer with multiple users simultaneously over a Wi-Fi network, or a wired LAN connection.
This compact wireless print server supports 802.11 b/g/n wireless standards for functionality with almost any wireless network, plus, serving as a primary or backup interface the print server also offers an RJ45 port for 10/100 Mbps wired connections. Providing wireless network printing access enables you to place your printer in any location with network access and avoids the added cost of purchasing individual printers for each workstation or area.
This wireless USB print server can have you up and running in minutes, using either a web-based interface or a Windows based installation wizard, and also features a Wi-Fi Protected Setup (WPS) button for quick and easy connection to your wireless network. Compatibility with USB 2.0 standards and a wide variety of USB printers and operating systems makes this network print server perfect for installation into mixed environments, with simple network management protocol (SNMP) support for remote monitoring.
StarTech.com 1 Port USB Wireless N Network Print Server - 802.11 b/g/n - print server
Print server
External
Interface (Bus) Type
USB 2.0
Ports
10/100 Ethernet x 1
5.8 cm x 7.2 cm x 2.5 cm
65 g
United Kingdom
Cabling Type
Ethernet 10Base-T, Ethernet 100Base-TX
10Mb LAN, 100Mb LAN, 802.11b, 802.11g, 802.11n
Network / Transport Protocol
TCP/IP, AppleTalk, NetBEUI/NetBIOS, IP/IPX, SMB
Frequency Band
2.4 GHz
IEEE 802.3, IEEE 802.3u, IEEE 802.11b, IEEE 802.11g, USB 2.0, IEEE 802.11n
White
AC 120/230 V
Apple MacOS 9.x, Apple MacOS X 10.x, Linux 2.4.x, Linux 2.6.x, Microsoft Windows Vista (32/64 bits), Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits), Linux 3.x, Microsoft Windows Server 2008 R2 (32/64-bits), Microsoft Windows Server 2012 (32/64-bits), Windows 8.1 (32/64 bits)
2 years warranty
Print server
External
USB 2.0
United Kingdom
Ports
10/100 Ethernet x 1
Wireless, wired
Cabling Type
Remote Management Protocol
SNMP
Frequency Band
2.4 GHz
Status Indicators
Status, WLAN, USB
1 x 100Base-TX - RJ-45
Encryption Algorithm
WPA, WEP
FCC, RoHS
White
External
AC 120/230 V
Software Included
Drivers & Utilities
5.8 cm
7.2 cm
2.5 cm
65 g
50 °C
0 - 70% (non-condensing)
Accessories
£4.44
£5.20
£4.58
£3.79
£6.13
£3.31
£5.01
Scroll to top
