BT.com
Wishlist
StarTech.com 1 Port PCI Parallel Adapter Card with Re-mappable Address
Delivery
Standard Due date unavailable
The PCI1PM Re-mappable 1-Port PCI Parallel Card adds a fully-featured, I/O mapped IEEE 1284 parallel port to your system using a PCI expansion slot.
Saving time and money in costly upgrades of legacy hardware, this re-mappable parallel card can be installed and configured using legacy memory ranges (278, 378, and 3BC legacy ISA addresses) under DOS and Windows operating systems, for compatibility with legacy devices such as security dongles that require a specific memory I/O range for operation.
The card also supports standard installations, with plug-and-play WHQL certified drivers for Windows, as well as support for DOS and Linux.
StarTech.com 1 Port PCI Parallel Adapter Card with Re-mappable Address - parallel adapter
Parallel adapter
Plug-in card - low profile
Interface (Bus) Type
PCI-X
Ports
IEEE 1284
6.1 cm x 12.1 cm x 1.3 cm
75 g
Parallel
Data Transfer Rate
1.8 Mbps
Microsoft DOS, Linux, Microsoft Windows Server 2003, Microsoft Windows 95/98/ME/NT/2000/XP, Microsoft Windows Server 2008 R2, Microsoft Windows Vista / 7, Windows 10 (32/64 bits)
Parallel adapter
PCI-X
Ports
IEEE 1284
Wired
Parallel
Data Transfer Rate
1.8 Mbps
1 x IEEE 1284 (EPP/ECP) - 25 pin D-Sub (DB-25)
Compatible Slots
1 x PCI-X
Low-profile bracket
WHQL, FCC, RoHS
6.1 cm
12.1 cm
1.3 cm
75 g
Limited warranty - lifetime
60 °C
5 - 95%
Accessories
StarTech.com 6 ft Parallel Printer Cable
Quicklinx: 76SW | In Stock
£5.46
Scroll to top
