BT.com
Wishlist
StarTech.com 1 Port Native PCI Express RS232 Serial Adapter Card with 16550 UART
Delivery
Standard Due date unavailable
Add a high-speed RS-232 Serial port to your computer through a PCI Express expansion slot.
The PEX1S553 PCI Express Serial adapter card allows you to turn a PCI Express slot into an RS232 (DB9) serial connection. The card is constructed using a native single chip design that lets you harness the full capability offered by PCI Express (PCIe), while reducing the load applied to the CPU by as much as 48% over conventional bridge chip serial cards.
The PCI Express (RS232) Serial Adapter Card is compatible with a broad range of operating systems including Windows 2000/XP/2003/Vista /Windows 7/Server 2008 R2 (32 and 64 bit), Linux Kernel 2.6.11 and up, as well as MAC OS X 10.4 and above. The adapter card includes an optional half-height/low profile bracket, that lets you add a serial port to virtually any computer, regardless of the case form factor.
This product is a replacement for the PEX1S552 card.
StarTech.com 1 port Native PCI Express RS232 Serial Adapter Card with 16550 UART - serial adapter
Serial adapter
Plug-in card
Interface (Bus) Type
PCI Express
Ports
RS-232
12 cm x 10.5 cm x 2 cm
Cabling Type
Serial RS-232
Microsoft DOS, Linux, Microsoft Windows 2000, Microsoft Windows 95/98 Second Edition, Apple MacOS X 10.x, Microsoft Windows XP Embedded, Microsoft Windows CE 5.0, Microsoft Windows Embedded POSReady 2009, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE 6.0, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
Serial adapter
Plug-in card
PCI Express
Ports
RS-232
Wired
Cabling Type
Serial RS-232
1 x RS-232 - 9 pin D-Sub (DB-9)
Compatible Slots
1 x PCI Express
FCC, RoHS
12 cm
10.5 cm
2 cm
-20 °C
85 °C
5 - 85%
Accessories
£4.57
£5.12
£4.65
£4.38
£4.21
£5.01
£4.89
Scroll to top
