BT.com
Wishlist
StarTech.com 1 Port Industrial USB to RS232 Serial Adapter with 5KV Isolation & 15KV ESD Protection
StarTech.com 1 Port Industrial USB...
£68.14
2 in stock
£68.14
Add to wishlist
Delivery
Standard 3-5 working days
Add a galvanically isolated RS232 serial port with ESD protection through a USB port - DIN Rail Mountable. The ICUSB232IS Industrial USB to Serial Adapter lets you add a galvanically isolated RS232 serial port with ESD protection through a USB port and offers a durable DIN Rail-mountable design.
Ideal for industrial environments, the USB serial adapter features an integrated 5KV galvanic isolation circuit and 15KV ESD protection, to protect costly and often sensitive control equipment against electrical damage. An extended operating temperature range (-30°C to 75°C) also helps to ensure performance in harsh environments.
For fast communication with serial peripherals, the adapter features an integrated FTDI chipset, supporting baud rates up to 921Kbps. The adapter also features COM retention that automatically retains COM Port assignments, even through a reboot.
The ICUSB232IS serial adapter is compatible with Windows, Windows CE, Mac OS and Linux which makes it easy to integrate into mixed environments.
StarTech.com 1 Port Industrial USB to RS232 Serial Adapter with 5KV Isolation and 15KV ESD Protection - serial adapter
Serial adapter
DIN rail mountable
Interface (Bus) Type
USB
Ports
RS-232 x 1
9.3 cm x 4.2 cm x 2.2 cm
25 g
RS-232
Data Transfer Rate
921.6 Kbps
Linux 2.6.x or later, Apple MacOS X 10.x or later, Microsoft Windows Server 2008 R2, Microsoft Windows Vista (32/64 bits), Microsoft Windows CE .NET 4.2 or later, Microsoft Windows 7 (32/64 bits), Microsoft Windows XP (32/64 bits), Microsoft Windows Server 2003 (32/64-bits), Windows 8 (32/64 bits)
2 years warranty
Serial adapter
DIN rail mountable
USB
Ports
RS-232 x 1
Wired
RS-232
Data Transfer Rate
921.6 Kbps
Status Indicators
Transmit, receive
Flow control, USB powered
1 x RS-232 - 9 pin D-Sub (DB-9)
1 x USB cable ( external ) - 1 m
FCC, RoHS
Software Included
Drivers & Utilities
9.3 cm
4.2 cm
2.2 cm
25 g
2 years warranty
Service & Support Details
-40 °C
75 °C
5 - 95% (non-condensing)
StarTech.com 1 Port Industrial USB to RS232 Serial...
£68.14
Save on this ideal PC Build kit!
Save £9.28
£87.73
Accessories
£4.38
£4.26
£1.38
£5.14
£4.98
Scroll to top
