BT.com
Wishlist
StarTech.com 1 Port Cat5 USB Extender 50M
Delivery
Standard Due date unavailable
StarTech.com's USBthere offers simple USB extension, allowing you to place a USB device up to 165ft (50m) away from the computer - 10 times longer than normal USB cable length restrictions. The USB extender is comprised of both local and remote units, which can be connected together to extend the USB connection distance over standard Cat5e Ethernet cable.
Delivering cost-effective USB extension, the USBthere USB extender eliminates the expense of additional hubs, repeaters, power adapters or software, making it perfect for a broad range of applications including security and surveillance devices like USB video cameras etc.
The USBthere is designed to provide dependable, long-lasting USB device performance over long distances.
StarTech.com 1 Port Cat5 USB Extender - USB extender - USB
USB extender - 4 pin USB Type A / 4 pin USB Type A
External
Data Transfer Rate
12 Mbps
USB
Max Transfer Distance
50 m
Microsoft Windows 98SE/2000/ME/XP
10 cm x 7 cm x 3 cm
0.1 kg
2 years warranty
USB extender
External
Wired
USB
Data Transfer Rate
12 Mbps
50 m
1 x USB - Type B , 1 x USB - Type A
1 x USB cable - 2 m
10 cm
7 cm
3 cm
0.1 kg
2 years warranty
Service & Support Details
4 °C
Accessories
£13.86
£4.34
£21.55
StarTech.com Mini 4 Port USB 2.0 Hub
Quicklinx: 5FRC | In Stock
£7.04
£14.37
£13.86
£3.79
Scroll to top
