BT.com
Wishlist
StarTech.com 1 Port 9in DB9 Serial Port Bracket to 10 Pin Header
Delivery
Standard Due date unavailable
Add a DB9 serial port to the rear panel of your computer. The PLATE9M 9 inch Serial Port Header Bracket adds a DB9 serial port to the rear panel of your computer, connecting to an IDC10 header connector on the motherboard.
Please refer to this product's Technical Specifications to ensure compatibility with your motherboard.
StarTech.com 1 Port 9in DB9 Serial Port Bracket to 10 Pin Header - serial panel - 22.9 cm
Serial panel
Length
22.9 cm
Connector
9 pin D-Sub (DB-9) - male
Connector (Second End)
10 PIN IDC - female
Serial panel
Length
22.9 cm
Connector
10 PIN IDC - female
Scroll to top
