Click to visit BT.com
BT.com
Wishlist
StarTech.com 1.8in ZIF LIF to Single Compact Flash SSD Adapter Card
Quicklinx: 6BD0WS00
Mfr#: ZIF2CF
This Compact Flash (CF) to ZIF/LIF Adapter offers a simple, do-it-yourself solid state storage solution that can be used in place of small form factor 1.8in ZIF/LIF hard drives. This innovative storage solution lets you enjoy of the benefits of solid state storage, using a standard Compact Flash card to replace a ZIF/LIF hard drive, including silent operation and little to no operating heat compared to conventional hard drives. The adapter features a small form factor that allows you to take advantage of the installed flash card's compact design - saving space while providing a suitable replacement drive for many portable devices, including the Apple iPOD, and small notebooks using 1.8in hard drives.
StarTech.com 1.8in ZIF LIF to Single Compact Flash SSD Adatper Card - CompactFlash Card adapter
5.4 cm x 7 cm x 0.6 cm
16 g
5.4 cm
7 cm
0.6 cm
16 g
Expansion Slots
1 x CompactFlash Card ( 3.3 V/ 5 V ) - type I/II
1 x storage - ZIF connector
UL, RoHS
Limited warranty - lifetime
