BT.com
Wishlist
Sony VPL SW525 - LCD projector - 2500 lumens - 1280 x 800
Delivery
Standard Due date unavailable
Designed for education, the VPL-SW525 WXGA (widescreen) projector provides the perfect teaching tool for glare-less projection in changing light conditions.
The VPL-SW525 WXGA (widescreen) projector with easy installation and multiple media connectivity is an ideal choice for ultra-close projection applications in educational markets.
Sony VPL-SW525 - 3LCD projector
3LCD projector - High Definition 720p
White
Built-in Devices
Speaker
Bundled Services
3 years PrimeSupport
Europe
Ethernet, Fast Ethernet
Brightness
2500 lumens
Contrast Ratio
2500:1
Resolution
WXGA (1280 x 800)
Native Aspect Ratio
16:10
Lens
Ultra short-throw lens
Lens Shift Direction
Horizontal, vertical
Bulb type
UHP 210 Watt
Bulb life cycle
Up to 3000 hour(s) / up to 6000 hour(s) (economic mode)
Video Input
RGB, S-Video, composite video, component video (SECAM, PAL, PAL-N, PAL-M, NTSC 4.43, NTSC 3.58)
Digital Video Standard
High-Definition Multimedia Interface (HDMI)
Video Modes
575/50p, 1080/60i, 480/60p, 720/60p, 1080/50i, 720/50p, 480/60i, 576/50i
Video Output
RGB
Speakers
Speaker(s) - integrated
280 Watt
38.44 cm x 42.34 cm x 12.25 cm
7 kg
3 years warranty
3LCD projector - HD 720p
Built-in Devices
Speaker
Bundled Services
Ethernet
Enclosure Colour
White
Europe
Projector
Brightness
2500 lumens
Brightness (Reduced)
1800 lumens
Contrast Ratio
2500:1
Image Size
178 cm - 330 cm
Throw Ratio
0.27 - 0.29:1
Digital Zoom Factor
4x
Resolution
WXGA - WXGA (1280 x 800) (native) / 1600 x 1200 (resized)
Native Aspect Ratio
16:10
Display Format
3,072,000 pixels (1280 x 800) x 3
Max Sync Rate (V x H)
93 Hz x 93 kHz
Bulb type
UHP 210 Watt
Bulb life cycle
Controls & Adjustments
Keystone correction, lens shift dial (horizontal), lens shift dial (vertical)
OSD Languages
Hungarian, Thai, Chinese (traditional), Chinese (simplified), Vietnamese, Farsi, English, German, French, Italian, Norwegian, Portuguese, Polish, Finnish, Swedish, Russian, Spanish, Dutch, Turkish, Arabic, Japanese, Korean
Eco-Mode technology, freeze frame, Picture Muting, Smart APA (Auto Pixel Alignment), Auto Input Search, 3LCD Technology, BrightEra, e-mail alerts, Direct Power On, Direct Power Off
Lens
Focus Type
Manual
Zoom Type
Manual
Zoom Factor
1.05x
Keystone Correction Direction
Vertical
Vertical Keystone Correction
-5/ +5
Lens Shift Type
Manual
Vertical Lens Shift
4% / 4%
Horizontal Lens Shift
2% / 2%
Video Input
TV System
Analogue video Signal
Video Interfaces
VGA, HDMI, composite video, S-Video
Video Modes
Video Output
Analogue Video Signal
RGB
Speakers
Integrated
Sound Output Mode
Mono
Output Power / Channel
10 Watt
Speakers
1 x mixed channel
Input Device
External
1 x component video / RGB input - 15 pin HD D-Sub (HD-15) , 1 x audio line-in - mini-phone stereo 3.5 mm , 1 x HDMI input - 19 pin HDMI Type A , 1 x composite video input - RCA , 1 x audio line-in - RCA x 2 , 1 x S-video input - 4 pin mini-DIN , 1 x RGB output - 15 pin HD D-Sub (HD-15) , 1 x audio line-out - mini-phone stereo 3.5 mm , 1 x serial RS-232C - 9 pin D-Sub (DB-9) (management) , 1 x network - RJ-45 (management)
Remote control
Mounting Kit
Included
UL, C-Tick, cUL, NOM, SABS, SASO, CB, CCC, EMC, IC, PSB, FCC, GOST-R, LVD, KC, KUCAS
Nominal Voltage
280 Watt
Power Consumption Operational (Standby)
7.5 Watt
38.44 cm
42.34 cm
12.25 cm
7 kg
Limited warranty - parts and labour - 3 years , Limited warranty - lamp - 1 year / 1000 hours
35 - 85% (non-condensing)
Sound Emission
35 dB
Accessories
£9.99
£6.94
C2G 5m Select High Speed HDMI with Ethernet
Quicklinx: 915L | In Stock
£18.78
£36.49
£49.42
C2G Pro HDMI to VGA Converter
Quicklinx: 9N1C | In Stock
£56.07
£17.48
Scroll to top
